Portable Cabins
Well thanks for all the input all points have been noted and taken on board.
Thanks.
"543.2.7 Where the protective conductor is formed by conduit, trunking, ducting or the the metal sheath and/or armour of a cable, the earthing terminal of each accessory shall be connected by a separate protective conductor to an earthing terminal in the associated box or other enclosure."
To my mind, this means that a fly lead should be used between the swith/socket front and the back box. Fixed lugs not withstanding.
+1 spin
Sockets and switches are metal clad and i do have continuity from them via the conduit
A earthing tail must be fitted
There is. cowboys convince customers to have unnecessary work done.
I'm not trying to cinvince anybody by what i told them.
And as it has been pointed by SpinLondon i was right to question it.
I'm not trying to cinvince anybody by what i told them.And as it has been pointed by SpinLondon i was right to question it.
I was on about the mention of dragging in an earth wire through the whole system, I never questioned the flylead from accessory to box.
or the earthing conductor in a house became detached........
do you see where Im coming from.?
if it is earthed its earthed,
where would you stop,?
maybe we should have a fly lead to the metal window frames, and drill a hole in the sink for a lug too, oh, and lets lug all the radiators too,
but what about the metal door handles.?
You may well say that Steptoe,but recently we had an EARTH bonding modification on about 200 cabins that came in that required us to fit 10 2"x2" aluminium plates on the inside of the cabin then fly lead all cabinets, lockers and acu frames to the in side.
Then out sides all external doors to the frames,in all there was 10 inside and 10 outside.
The MOD do advocate overkill when it comes to any think electrical.
So that was about 2000 plates,8000 rivets,200 clinch nuts,8000 ring crimps yellow and then the cable about 1000 mtr 6mm trirated.
So basically that's why I was querying the earth cable in the switches.
"543.2.7 Where the protective conductor is formed by conduit, trunking, ducting or the the metal sheath and/or armour of a cable, the earthing terminal of each accessory shall be connected by a separate protective conductor to an earthing terminal in the associated box or other enclosure."To my mind, this means that a fly lead should be used between the swith/socket front and the back box. Fixed lugs not withstanding.
:Salute I had the same discussion here years ago with steps about this
Bacon,
it seems you are new to all this,
we done all this in the 15th(was it?) edition,
then had to undo it all again in the 16th.
sorry,
it was a bit of a **** take, where do we stop?
and where or when do they change their mind......
It won`t happen, Albert.
We`re to deduce the capabilities of the O/P from their posts - keeps us on our toes.....
For my tuppenceworth.... If the metalclad boxes have an earth connection (switches) to the back box - you can`t fail `em. Socket outlets - okay, as Spinny says.
The best point made, AFAIAC, is our Lurchio: If you note something, have the reg that backs it up. If it doesn`t have a reg attached, the only thing you can do is verbally recommend..........
KME
if I read that again then Bacon,you are not a spark then,?
is that correct?
I really wish people would post up their position before questions.
And as for not being a spark is a bit offensive as I've probably fixed, installed and repaired machines you may have not even seen or worked on as well as building c/panels and installed all types of wiring systems,
But that doesn't make me any less than you or KME to carry out electrical installations.
And being a member of a scheme make you all the better?
Chris: Take your point, and fully concur.
However, I understand a "metalclad" box to be a different animal than a metal back box; and was posting on that proviso mate. Or am I woofing up the garden path here??
Chris: Take your point, and fully concur. However, I understand a "metalclad" box to be a different animal than a metal back box; and was posting on that proviso mate. Or am I woofing up the garden path here??
Maybe ive misunderstood your post:|
I was replying to the ops point that accessories need an earthing tail to the metal back box as per 543.2.7
ladies and gentlemen
may i remind one and all of the pointlessness of angry replies and insults to other forum members
the moderators will remove them
so you waste your time writing it
and make us spend time moderating it
IF you feel slighted by another member, send them a pm about it
with a request for a retraction
or contact the moderation
or administration staff
vigilante replies will not be tolerated
i hope this is clear to all
thank you
mr smith
Maybe ive misunderstood your post:|I was replying to the ops point that accessories need an earthing tail to the metal back box as per 543.2.7
Ah! Now we`re on the same train...........
It was your quote of my post that confused me bud.
Yes, 543.2.7 refers in the case of a metal pattress ;) :innocent
KME
I have a habit of not reading the whole thread;\
Though i concluded that Bacon was referring to accessories not not having a earthing tail connected to the metal back box where the conduit was the cpc
Having carried out these PIR's on the mentioned cabin i have also noted a non compliance on the VOLECB that are fitted on the front of them, codes 2+4 as these all have to brought upto the 17th regs.
And as for not being a spark is a bit offensive as I've probably fixed, installed and repaired machines you may have not even seen or worked on as well as building c/panels and installed all types of wiring systems,But that doesn't make me any less than you or KME to carry out electrical installations.
you were unable to even identify the earthing system, and as yet unless I have missed it somewhere have still failed to inform us of the earthing system so are you really surprised as to why I questioned your competence based on a basic fact of safety.
being able to wire something doesnt make you a spark,
I build racebikes, but Im NOT a mechanic,
I even made some buns the other day, maybe I should call myself a baker.
being able to follow a drawing simply proves your eyesight works.
