correct. this can be as low as a few amps for TT, or many hundreds of amps for TN.Hi there, Am I right in saying that this is the maximum current that will flow in the case or negligible impedance between phase and earth?
Is the equation for PEFC: If = Uo / Zs?Don't confuse PEFC with PFC or PSCCPEFC - prospective earth fault current (L-E)
PSCC - prospective short circuit current (L-N)
PFC - highest of the above
Zs = Zdb when the DB is not connected directly to the origin of the supply.So, in the case of a DB2, isn't that effectively the Zs then mate?
