Question
mort2376
The devil's in the details, or the dodgy wiring !
Apr 27, 2015
538
357
Preston, Lancashire
Working away in the foreign land they call London.
Incoming dno cable into a basement flat is cloth covered as shown in photo below.
Should this be upgraded ? Not the neatest dno install i know.
Thoughts please good people.
Yes i know there is something missing from the cut out. That's because I'm fitting a new Cu and I asked the seal fairy last night to remove the seals, and magically this morning they were gone 🤔☺️
    1.8 MB
    1.8 MB
    1.8 MB
The head at some point has been changed so someone thought it was okay. Not ideal it is hanging it's weight on the head but have seen plenty of these like washing lines across basements, London is full of them.
the cable is oil filled, and only really becomes an issue if it is leaking the oil, which then allows it to dry out, which then allows it to fail. So in short, I would not be bothered about it if it's not dripping from the end.
