HiRight a young mother down the road from me has two autistic boys, which have just started to get upset and cries whenever she turns a socket or light on. It
Don't think there is anything in regs to say they have to be switched as they are shuttered but generally switched ones are cheaper these days so thats what you use.Might as well just use switched ones and not turn them off. I'm not a fan of using unswitched sockets for general usage, not so sure it would always comply with BS7671 either as you don;t want to be plugging\unplugging kit under full load.
varilight, you can get a remote for them aswelI've always found Clipsil socket switches to be quite.There was a touch plate for a light switch, I believe it also acted as a dimmer. Touch it once for on, again for off and if you hold your finger on, it dims or brightens. Can't remember the Company though.
I'd appreciate that.HiMany thanks to you all, I have gone through all the posts and have noted all makes and suggestions and will try to check out as many as I can over the next few days.
We are going with the pir option for the bathroom, as this is the main one which sets the boys off.
So is it OK to go ahead with unswitched sockets? As that might be the best way for the boys room, but will check out a few makes to see which would do for the rest of the house
Will also price up some touch plate switches tomorrow as this might be the best for her, not sure what the best make is but my local shop did say he would do his very best price if he has it in stock so will find out what make he has in stock and see what you good people think.
Once again, many thanks for taking the time to reply,
Lyngarth
Then he may like this one that I added Today. (Oh, and I have added plenty more too).bad day explode bad day explode( I had to put this on as David, the youngest boy can't stop laughing at it )
She is most Welcome. :xP.S His Mum has just said to pass on her thanks to all of you for your help.
Agree 100%I think threads like this are what makes this forum all worthwhile.even though I had absolutley no input to it whatsoever.
