I find a lot of RCD's have been wired with the clean switched contacts oriented to the buzzbar presumably through convenience in older CUs made from multi brand items. Usually situated at left, feeding the MCBs to the right. Is it worth correcting these cases so that the feed is above as intended, and the load wired back up underneath to the top MCB buzz?
