Re: Bathroom pull cords
Dambo
Oct 7, 2009
473
Why are pull cords used in bathrooms? Is it just to avoid the ingress of water?
Simples I guess!
Naked ,wet bodies, so no sockets , no wall switches.
Not true any more though. If you have a big enough bathroom your feet are technically dry enough for you to have a plug socket and a normal wall switch :D
AFAIK
Point taken Patchy, you have to check the zones. We are doing a bathroom tomorrow , the shower cabinet has a television and stereo radio built in . Why you need TV in a shower is beyond me but there you go ! What would you watch, Scrubs or the Soaps. Cracker ??
I've never really understood how someone can get a belt off of a non conducting plastic switch.
If you cover the lugs up with the plastic insert thingys most switches have provided now I don't see the problem.
"reasonable provision" is how the saying goes... O)
corrie street B-) :D :^O:^O:coat
prob watch p**n, the shower provides easy clean up.
have i crossed a line, i have a tendency for doing that
prob watch po*rn, the shower provides easy clean up.have i crossed a line, i have a tendency for doing that
ROTFWL
You have been thinking about that in your spare time!
I've never really understood how someone can get a belt off of a non conducting plastic switch.If you cover the lugs up with the plastic insert thingys most switches have provided now I don't see the problem.
Wet hands skiding across the plastic switch - moisture seeps around the edges of the rocker, provides "tracking" path for the eletric trickery - ZzaP!!!
yeah and cheap switches tend to have a habit of arcing like a goodun when switched.
I saw a house when I was in NZ where the bathroom light switch was in zone 1 right behing where your head would be about 300mm up from the top of the bath. AND it wasnt SELV - I don't think they would know what that was!
All switched ark. Cheap ones have thinner plastic so you can see!
Remember - if you smell gas, don't turn the light on. Get a candle instead...........
:D
Hmmm yes, but the same rule should apply in kitchens then?
Anyway, not wishing to be a reg head but 701.512.3 effectively bans switches, it's just a silly reg I don't agree with and have never done :|
(It doesn't appear to be a problem in other countries)
edit: added a bit
Hmmm yes, but the same rule should apply in kitchens then?Anyway, not wishing to be a reg head but 701.512.3 effectively bans switches, it's just a silly reg I don't agree with and have never done :|
edit: added a bit
EH?? you don`t agree with the "silly" 701.512.3 ???
So you`d be happy having mains switches at any point in your bathroom?
I`m sorry, that seems to be a complete & utter "silly" comment, IMO.
KME
EH?? you don`t agree with the "silly" 701.512.3 ???So you`d be happy having mains switches at any point in your bathroom?
KME
Agree, you're hardly likely to be walking around the kitchen in the buff splashing water everywhere, (well maybe in some parts).
There's a world of difference between a kitchen and a bathroom with regard to safety.
Bez
