The thing is the Acti9is designed for industrial & commercial loads, not domestic, so it is much more robust, mind it is not 100% 125A rated, it does have a diversity factor.
Hi Dave,
No problem. I could ship what you think you might need and Invoice you what you use, after you send back what you don't need.
You don't have an Account with me, but I am happy to deal with you on an open Account on this job.
It would be best to communicate via e-mail, as I don't visit the Forum on a daily basis.
SBS Dave
[email protected]
I have sent an email.Hi Dave,
SBS Dave
[email protected]
My gut feeling is that a single 50A load that's on for a long time frame is pushing the limits for anything that is intended as a domestic board.
I think for me it would have to be one of the two answers that has come up in the thread in various ways:
A) Fit a commericial type A board, such as schneider.
B) Use your preferred brand of consumer unit (such as SBS compact RCBO based board) and sit a separate switchfuse for the 12kw of water heating. At one time I would have suggested a wylex 160CM, as they have twin terminal screws, plus you can loop 25mm² tails in and out of the supply side so avoids henley blocks. However they have replaced it for Amd3 (why? - it was mainly metal anyway, plus the plastics in the standard range never did go all drippy when hot!) The replacement I think still features twin terminal screws but you cant loop in and out
If I do adopt the SBS solution, as well as dual busbars, high current main switch etc, I would configure it so the 50A rcbo has a clear vacant space either side of it as well.
The solution I am discussing wth Dave will have 3 spare ways, so I am thinking:
Main switch
space
50A for boiler
space
40A for cooker
space
40A for shower
rest of mcb's small / larger ratings intermixed.
that gets the two that are likely to draw big loads for a long time out in the open.
Label? instead of "spare", "MCB Heat Dissipation gap" or similar.Whilst it's a good idea, I'm always concerned that the leaving of space between heavy loaded mcbs is tempting fate in itself? If an additional circuit was to be added then the likely hood is that it will be a radial to a relatively high load, such as hot tub, garage/workshop? Which would then substabtially increase the problem you are eliminating?
Just thinking out loud................
Fair point, well made, but not impossible.maybe, but if this is one of dave's boards, then it wont simply be a case of fitting another breaker due to busbar design
True, but would the average 5ww understand the importance?Label? instead of "spare", "MCB Heat Dissipation gap" or similar.
Maybe, if other ways further along were labelled "spare", you can only do your best.True, but would the average 5ww understand the importance?
