Bah, just grind the fingers off the bus bar!
:coffee
:coffee
Whilst it's a good idea, I'm always concerned that the leaving of space between heavy loaded mcbs is tempting fate in itself? If an additional circuit was to be added then the likely hood is that it will be a radial to a relatively high load, such as hot tub, garage/workshop? Which would then substabtially increase the problem you are eliminating?
Just thinking out loud................
I suspect most people would just slap in a mk/wylex/crabtree/bg etc CU without a second thought in a job like this, and then be puzzled in 6 months time when they get called back because something has gone wrong.The earth and moon may collide next year.
You can only plan for known situations, what the next electrician does is his problem not Dave’s. So long as Dave leaves the job in a safe and serviceable condition then at that point his responsibility ends (subject to terms and conditions.)
I don't disagree with you Tony, it's just a sad fact that so many 'electricians' don't understand the principles of design and inevitably will do something that will be detrimental to the installation and ultimately cost the customer more money for nothing.The earth and moon may collide next year.
:coffee
We do seem to be breeding a different class of idiot nowadays. bad day explodeYe, its not as if I've been to look at a job where the spark couldn't get a new circuit to work where it was a wylex breaker in a sqD plug in busbar ,???? :C
You can't account for stupidity
Grind the fingers off
I have to say that is one of my hobby horses . I've done a few threads on the subject . I have always found many electricians who start to plan for unforseen , unknown , possible future actions that may or may not be taken by other sparks who may or may not be called to the same job at some , possible , date in the distant future. Or not , as the case may be.The earth and moon may collide next year.
I take your point Apprenti but I'd already spoken to the customer , couldn't do it for weeks so passed it on . This guy just decided it was going to be a working garage .Yesssss, but equally, i have spoken to more than a few householders that were very disappointed when their new welder/compressor/whatever could not be used in their garage.. To them, you have either got an electric supply or you have not. If anyone asked my advice about electrics in garages i would ALWAYS explain the options, and tell them that if they DO go for a teeny weeny supply, that they will not be using such stuff in future.
A much bigger laugh is "electricians" that do not appear to know anything about volt drop.. Have seen loads of cables sized on the basis of current, and then they wonder why their motor will not start!! [and i cannot see the appropriate OCPD operating correctly either]
john..
