I had a ceiling rose with a bulb under my stair case that kept getting hit with coats etc and this was connected to 2 LED strip lights from TLC the 2 strip lights were connecting via a linkable cable with the last LED light connecting to the ceiling rose - see attached picture. Because of my predicament mentioned above I decided to buy a third LED strip light to replace ceiling rose and bulb and connect all three LED lights to a switch rather than a pull cord, like before.
The switch has a COM and L1 connectors and the wire from board twin and earth. I have connected these up previously and have never had as much trouble when connecting these up.
Can you tell me how I should connect the twin and earth cable coming from board - Red and black and the colour cables from the last LED strip lights which are blue and brown.
No matter which way I connect these up, it trips when I switch on from fuse board.
