Is it possible to install a Ring floodlight pro as the title says with just a cable and a plug on the end? And if so what cable would i need, but also what fuse is needed to power it? Because at the location i've got no outside wiring, but i've got a window i can feed the wire through into an extension lead. Thanks.
