That is correct. What you can often do to test if this is the case is. ' throw' the lever as hard as you can so it travels further than normal travel. If this works you will hear the micro switch operate for a second or two.As the guys have said there is a micro switch within the valve head,,, however you cannot manually move the mechanism far enough to operate the switch, it only allows you to open the valve
