hi
I have been asked to do 3 security lights. 2 at front door with 1 at back door. 3 x 300w lights with p.i.r's and a switch next to the front and back doors. the consumer unit is under the stairs at mid point. was thinking of taking one feed from the board to the front door switch and another feed from the board to the back door switch (1.5mm), both from the same 6a mcb. then run a 3 core up to each light from the switch with the neutral in a crimp or connector. I cant use double pole switches as they will be 2 gang switches with the hall and conservetory lights. I have not done it this way before and just wonderd if it is ok.
