electrics_new
HI All
Advise needed please...........
OK went to a job today to change over some lights in bathroom. However, while i was there - noticed that the hower pull switch is located within the shower tray.
Albeit, outside of the prescribed zones as the ceilings are more than 2.25M height.
The Plumber left it where is was line...............
OK - issue is that it doesn't look to good there. Customer wants me to replace it with a 45AMP Switch so pull cord doesn't hang down.
Anyway............. i said i'll get back to them on that part of the job.
From my knowledge you can't get an IP Rated Shower Switch and if you could how you going to switch it off to isolate it if need be ??????????
I could put blanking plate and trace the cable and so put a switch outside of the bathroom but we got issue tracing cable and the fitted wardrobes outside of the bathroom.
ANY PRACTICAL ADVISE ???????????
thanks in advance
thanks in advance
