green-hornet
Distinguished Member
- Feb 25, 2009
- 3,741
- 0
but Volex:O:O:O:O:O:O:_| :_| :_| :_| :_| :_| :_| :_| :_| wylex or crabtree for me Applaud Smiley
They are normaly crap! but this is a personal view and in no way reflects the qualitity of a first class mass produced piece of plastic which should be thoughtfully disposed of (as soon as possible).whats wrong with volex? good value!
it is interesting how we develope our own little prejudices!Volex crabtree and wylex are all from electrium group probably made in the same factory in china or some other place.Batty
I quite like volex. Allways use them on outbuildings as you can terminate an swa through 25mm nylon gland direct into them. Never had any call backs on failed Rcd's must have fitted at least forty since I have done outbuildings. Never used them on houses as I usually use either MK or Contactum. But I cannot see a problem with them. Now Wylex is another story have had a lot of call backs on there failed gear.it is interesting how we develope our own little prejudices!![]()
what about Moeller?I quite like volex. Allways use them on outbuildings as you can terminate an swa through 25mm nylon gland direct into them. Never had any call backs on failed Rcd's must have fitted at least forty since I have done outbuildings. Never used them on houses as I usually use either MK or Contactum. But I cannot see a problem with them. Now Wylex is another story have had a lot of call backs on there failed gear.Batty
Not tried one yet but may take a trip into wf when I get a minute to take a look.what about Moeller?any good?
I've got one in my house! 16th editionNot tried one yet but may take a trip into wf when I get a minute to take a look.
Take a pic, is it an x board.I've got one in my house! 16th editionjust wondered!
x board?Take a pic, is it an x board.
x board is what they call the ones they do now link below.x board?It's split load?
I'll take a pic tomorrow - camera in the car
looks similar - will post picsx board is what they call the ones they do now link below.http://www.moeller.co.uk/documents/xboard_consumer_units.pdf
fairy snuff,Care to explain this?![]()
The Moeller cat page 82fairy snuff,I sit to be corrected,
sorry,
but I still reckon MOST MCBs are not rated >240v,
as most main switches are also not rated >240v, (I know some are, ie HAGER)
maybe I'll have to try find out some more about this,
I was always under the impression there was a big NO NO in using 1Phase stuff on 3Phase boards.
All the MCB's i could find in my van (merlin gerin, MK, crabtree and some others) were all the samefairy snuff,I sit to be corrected,
sorry,
For BattyTake a pic, is it an x board.
Cheers patch I may give them a try they look like they have more room for Rcbo's as busbar is quite low down. I tend to fit Rcbo's rather than 17th edition boards.For BattyMy CU
http://i281.photobucket.com/albums/kk210/mikeywoodhouse/PICT0007-1.jpg
Both of them together
http://i281.photobucket.com/albums/kk210/mikeywoodhouse/PICT0008-1.jpg
Lift the lid
Got a proper electrician to take the front off incase you wanted to see
It's a Moeller BC-P165R80
rated AC 240/415/50Hz IP40
is an RCD acceptable (under 16th) as a main switch?Cheers patch I may give them a try they look like they have more room for Rcbo's as busbar is quite low down. I tend to fit Rcbo's rather than 17th edition boards.Batty
