- Feb 27, 2008
- 11,018
- 0
This has been discussed in great detail in a previous thread.
Batty
Batty
EAWR comes to mindSo Steps,Are you saying that when you change a CU, you leave the tails live??
Or do you get your DNO out to isolate?
Or has the seal fairy been? (In which case you are still not legally allowed to remove the main fuse)
Tut tut u been cutting the sealsNot really, Mine is brand new and says 100 A on the front of it. But it is actull 80 A, because WPD are too tight to give out 100 A's.
In my views it matters NOT what is in the main fuse and sealed in place. If it says 100a YOU TAKE IT AT THAT. Its the way I was trained and the way we should think. 'assuming' its not 100a when it states it is is not a good idea.I have been asked to quoe to replace a consumer unit with a new one. When I went to look at job I found that the flat has two consumer units fitted (wylex rewirable jobbies) one of which controls an economy 7 heating (storage heaters) and hot water immersion heater. the incoming supply is fed from a 100amp supply to a henley block where the tails are split to two different meters. From these meters tails go to each consumer unit. The 'normal unit' is fed by 25mm tails the economy 7 unit has 16mm tails. As i plan to renew the tails do I need to upgrade the tails to the economy 7 unit to 25mm. Hope this makes sense. I can't find anything in the 'wiring regs' but the on site guide says that meter tails should be 25 mm
Nope, I was the one that requested a higher Ampage. They came, told me it was too old to do and came back at a later date to redo it all. They put an 80 A in.Tut tut u been cutting the seals
hi binky, I'm in St Austell. Applaud SmileyYep that's western powers' standard answer. Where abouts in pasty land are you then?
Hi shocking.In my views it matters NOT what is in the main fuse and sealed in place. If it says 100a YOU TAKE IT AT THAT. Its the way I was trained and the way we should think. 'assuming' its not 100a when it states it is is not a good idea.You have to make provisions for what it 'could' be!
That is also how the NICEIC will view it. They know as much as you about what fuse link is sealed under there and will expect provision for what is actually stated on the cover.
100% concur.just as an aside,when Im filling in my forms, whether 25mm tails or 16mm, I virtually always put down my main fuse as
UNVERIFIED
if I dont actually see it then I cant verify the size.
Apache:I'm no expert on these things but Steps is right. Unless you can physically see it (permission to cut seals) then you have to state it as unknown. You can't sign a certificate to the effect of a 100A fuse if there isn't one...........
