Sparking Storage Heater
paulal
Jan 13, 2014
3
Hampshire
Hi
Just turned down the charge on the storage heater and this massive spark came out, bigger than the normal little spark when turning it off, is this normal.
its a rented property and don't know if its normal enough to call the landlord.
Your advice would be most welcome.
Paula
Hi
I have no idea how old it is as a rented property
There is no name on it but it looks like the Dimplex ones.
You may see a large spark or a small spark when the contact
opens;  it depends exactly when in the current cycle the contact
opens.  Large if it is at the peak, small if it is closer to zero.
As Steve says, age is a factor.
