mattrandall
- Sep 24, 2011
- 7
- 0
I have found in my kitchen that a 10mm supply in singles has been installed for my 2 new ovens. As the ovens are isolated independently the 10 mm has been split into 2 x 6mm singles. An earthing block terminal (bare metal type as you would have for connecting multiple earths ) has been used and housed in an enclosure (ip rated although it's inside). Is this a viable solution and will it be ok? The ovens are 4 kw each so pull a combined total of 32 amps roughly at max. Please help as it's being boarded in shortly and access will cause damage
