get the yellow pages, go to 'electrician' section, call someone and let them do the jobWell what can I do then
Well I'll tell you what seeing as you obviously have such a poor grasp of the regulations, just send me the address and I'll go and do the job for you,, or maybe you should look for someone more localNozspark I have looked it up in the regs and it shows the spur between a leg in to an fcu in 2.5 out of that feeding 2 sockets in 1.5 So I would say yes the way I said was ok.End of the day Im asking a question yes I will do anything to make it rcd change the breaker over on to the rcd side in a more up to date board.The one I mentioned is re-wirable on some i put the rcd spur at the board these are seperate boiler circuits though.
