Spur
Well what can I do then do away with the sw fused spur and put a 3 amp in that
In the rcd spur that is
Thanks il just put the rcd spur on and do away with the sw fused spur
do u have the correct testing equipment to complete the certificate at the end of the job etc....
amd know how to use it???
Nozspark I have looked it up in the regs and it shows the spur between a leg in to an fcu in 2.5 out of that feeding 2 sockets in 1.5 So I would say yes the way I said was ok.End of the day Im asking a question yes I will do anything to make it rcd change the breaker over on to the rcd side in a more up to date board.The one I mentioned is re-wirable on some i put the rcd spur at the board these are seperate boiler circuits though.
Well I'll tell you what seeing as you obviously have such a poor grasp of the regulations, just send me the address and I'll go and do the job for you,, or maybe you should look for someone more local
RB you are not doing yourself any favours by not answering the questions as put to you by the members yet you expect your questions to be answered? I would say that you are bordering on the verge of cowboy/diyer with the level of respect that you fail to show those that are trying to assist you. There is nothing wrong with asking a question albeit basic if you are honest as to your abilities in the first place. Too many people these days think that a qualification or reference book makes them qualified to real world scenarios, why people can't be honest is beyond me, is it an insecurity thing? With honesty comes respect which is a two way thing.
Just advising!!
