paul b b
thanks lost it! whooo thought i did some thing wrong there lol
i have to do a 4 gang on thursday, gawwd look out
lol thanks Bengie.damn my dinner eating and slow drawing!!
You'll know for next time, I always loop at lights (unless its easier at SW or JB), dunno why though.thanks sellers.i should have made it easy and looped in the light, but never mind
dress it neatly and strip the cables back to only just after they enter the box and connect up the cores logically and it shouldn't be a problem, i don't understand why you can only use 25mm deep boxes, is the partition wall very shallow?this 4 way light is silly2x feed
1x pendant
1x wall light
1x spots
1x 2 amp socket
4x strappers
all in 1 box and can only use a 25mm as its lath and plaster
the wall is literaly, plaster lath, plaster.dress it neatly and strip the cables back to only just after they enter the box and connect up the cores logically and it shouldn't be a problem, i don't understand why you can only use 25mm deep boxes, is the partition wall very shallow?i removed a lath and plaster facing from my bedroom and replaced it with plaster board but the partition is still made with 4" timber so plenty of room available.
you could always add a shallow surface box to add depth.the wall is literaly, plaster lath, plaster.if i cut out the lath the plsater on the other side will fall off
blimey, what on earth are the laths fixed to?the wall is literaly, plaster lath, plaster.if i cut out the lath the plsater on the other side will fall off
Normal dimmers are simply wired as standard 2 way switches. You only have 1 dimmer per group though at one end or the other.forgot to ask, you mention dimmers on the coming 4g switch. i personally have neve fitted normal dimmers 2 way so i don't know they interact but in my bedroom i have installed 2way and intemediate electronic dimmers, which was interesting.
