Either end. They just replace a 2 way switch so wire as normal and put the dimmer in place of a 2 way switch.on the note of dimmers. can they from the strapper end? or only the feed end?
Why not what? Why doesn;t it matter which end? They're just 2 way switches, so can go on either end in place of any 2 way.why not?
I was going to say I'll let you work that out as I'm sure it will come to you, but someone might tell me to not be so unhelpfull or something so the difference is, one is rated at 400W and the other at 250W.and what is the differance between 400w and 250w dimmer switches?
lol, be carefull now.I was going to say I'll let you work that out as I'm sure it will come to you, but someone might tell me to not be so unhelpfull or something so the difference is, one is rated at 400W and the other at 250W.
if you want to be able to control the light level from either end this is possible, i fitted some dimmers 2way and intemediate in my own home and they aren't that dear really, the main dimmer was around
No, steady on. If you get a standard dimmer you only use one and connect it to one end of the 2 way circuit. Bengie is on about some fancy electronic ones.i thought that this was a no no.ok i will look into this. so i need to get a set right? consisting of a main and slave.
No, steady on. If you get a standard dimmer you only use one and connect it to one end of the 2 way circuit. Bengie is on about some fancy electronic ones. Standard dimmer <
