Do I need to Supplementary Bond under a boiler anymore? I have wired a lot lately on TT systems, does this make a difference? I have the Main Protective Bonding to the Gas and Water supplies and the RCD operates within maximum disconnection times.
did you ever need to?Do I need to Supplementary Bond under a boiler anymore? I have wired a lot lately on TT systems, does this make a difference? I have the Main Protective Bonding to the Gas and Water supplies and the RCD operates within maximum disconnection times.
Yes. However it was never an electrical requirement, but a gas reg.did you ever need to?
PS: it is still a requirement for oil boilers as the BS applies to gas boilers onlydid you ever need to?
