SWA electric cable in a 10cm depth drive drain
Adickinson
Jul 7, 2019
I am getting an electric car in September and been talking to charge point installers.
I have a 56 metre run from fuse box to garage where car would be parked. Looking at 10mm2 SWA 3-core cable on 32 amp supply. Would this be sufficient a mm2 for
length of route.
Im burying it down to 45cm where I can except  under paths. I have a Hauraton drain on my drivr
which is 10cm deep and has metal grates on it. Was speaking to an electrician via a builder
neoghbour. Who said I could
run SWA directly in the channel by drilling into paving edges either side. So So cable would remain underground. Would concrete over anything less than 10cm down on either side and take cable down to 45cm.
This is a picture of length which is about 6 metres.
https://share.icloud.com/photos/0QyGp5fy0fY9fPDm_dkepmvxA#Home
Each side has a concrete edge on it,
https://share.icloud.com/photos/06duNQmN6TAwejBPh1pbcW-Bw#Home
so was planning to drill a 30mm hole into concrete for SWA cable and run on bottom
of plastic drain. I’d checked with installer and another electrican. But to be legal hence question before doing anything.
andrew
I,have never met your electrician or builder but they do not appear to know what they are talking about?
if he thinks it's safe then let him do it and sign it off!
