moose man
- Aug 8, 2009
- 510
- 0
ifyou have to use swa if the consumer unt is more then 3mtr away frrom service head
on a tns system and a 80A incommer how do you get on if your exsisting tailes are 25mm and main earth is 16 mm as i have not come across this before i know to put you have to put switched fuse in but at @ 80A but discrimination between switched fuse and service fuse
all so how about sizeing 16mm 0r 25mm swa and do you use 3 core the 3rd core as the earth
to comply when the main earth is 16mm
i know it sounds a daft quiestion but i am just pondering on it thanks
moose man
moose man
