Bev
We have just bought a property and are switching from the existing Economy 7 system to a single tariff system with radiators from EcoPower Heating. Will this switch affect our water heater? Currently there are two switches; as i understand it, the top switch is a 'boost' button which is expensive but will heat water as and when needed. the bottom switch we have on all the time which seems to heat the water periodically in the day.
when we make this switch, will we only be able to use the boost button? If so, is there anyway we could set a timer to have the water heated as normal, without having to pay for an expensive 'last minute' water heat up?!
Any advice will be appreciated!
Thank you!
Thank you!
