symbols on building plans
Theorysparky
Domestic Electrician
Feb 18, 2008
4,232
I can normally read plans ok but i think this guy (architect) has made these up
the symbol he is using for a socket outlet is a half circle with a dot on the outer edge then a line (two of these side by side)
he has the same symbols again but blacked out again two of them these appear either side of the cooker
any ideas
by the way there is no a key on the plans
Not made up the half circle with dot and line is a switched socket, double is 2 side by side and the blacked out ones are FCUs.
Blacked out circle with line is light switch, sgiggly line is pull switch
Not made up the half circle with dot and line is a switched socket, double is 2 side by side and the blacked out ones are FCUs.Blacked out circle with line is light switch, sgiggly line is pull switch
cheers Tim
are these found on certain types of software ??/
i thought there was a industry standard
I would say that is very basic. Any engineering drawing should have a key. When I were an automotive engineer I would never have issued a drawing without one.
I would be very tempted to reject the drawing as incomplete and request a key. Don't leave any room for ambiguity, especially if you could end up wrong.
If he has used symbols from a standard, then instead of a key the drawing should contain a reference to that standard in the notes. A key should still be used for any non standard symbols.
Back cover of On site guide, but often there are "variations".
thats where i looked initially
i have read commercial diagrams and it was obvious what was going on without a key.
Yup they look pretty standard, circle with cross is probably recessed down light, S is smoke alarm, maybe the key is on another page?
but not OSG standard which confused me
so what programs use this or is it an industry accepted format
need to find the key,,,,feeling like pratt at the mo... :^O
Not sure of programs but yes I think you will find this is fairley standard.
To be honest the plans I have worked from have normally had key, but without it You should be able to work out most of them, if there are any on there you are not sure of post them up and we will try and assist.
Most plans I work from have a key, the problem with most architects is they are not up to the current regs and use available software for their plans.
I always double check the lighting specs for instance, I have found that a requested and specified fitting does not comply or is unsuitable for the purpose.
Not sure of programs but yes I think you will find this is fairley standard.To be honest the plans I have worked from have normally had key, but without it You should be able to work out most of them, if there are any on there you are not sure of post them up and we will try and assist.
+1
Im not meaning to be awkward or anything,but is this one of the things we have lost in proper apprenticeships.?
Symbols remain the same and we all learned them but some designers will impose their own *******ised copies, leaving us all to wonder what the hell is that?
IEE OSG
IEE Electrical installation design guide
IEE Electricians guide to the Building regs
All have the same symbols
I thought the IEE were the boys
not Andy the Architect make it up as i go along bloke
if the symbols on those plans are 'the industry norm' why are they not in the publications ?
IEE OSGIEE Electrical installation design guide
i know where your coming from TS but in the industry you'd be expected to decipher little anomalies like this very quickly and get on with it :popcorn
