johncassell
- Jun 15, 2016
- 3
- 0
Hi all, we are using a Cat5 cable from the patch panel in our server room down to a little office for telephone purposes. The length is about 70 metres. The problem is this - on a morning our staff come in and this particular phone isn't working (faint crackily noise only). We only need to use 4 of the 8 cables inside the cat5 and I so I attempt to reseat the connections in the telephone socket box on the wall. This usually doesn't work. A day later I could try the very same thing again and the phone springs to life. The next morning (something seems to happen at night) the phone has gone back into its crackily state.
There is continuity in the 4 cables back to the patch panel and I know the port in the actual telephone system works fine (as if I plug a phone directly into that, then it works every time). Would anyone have any advice as to what could be causing this to happen? My boss suggested a dry joint so I cut the cable a bit further back and reseated back into the wall socket - I thought this had fixed it but next morning dead again.
Hope someone can help. thanks, John
