paulcopeman
Active member
is it a requirement to have a thermal switch on the thermostat in hot water tanks
so it would be an observation on a EICR if no cut out switch with advisory to have one instaled?
NO,Definitely
non compliant with what reg.?Well,,, I would always note the fact of a non-compliant tank stat on an EICR,,, however I wouldn't give it a code
as slip has saidIts only code-able if a non metalic header tank is in use.
I agreeNO,
unless you dont word your test sheets correctly,
I dont see why we have to ensure the clients equipment is adequate,
do you also check the cooker has an overload/overtempo stat fitted.?
test to the point of local isolation only.
The place to look might be the Water Regulations. Some plastics are onlybut I don't remember there being a distinction between plastic and metal headers
