You have MK & Crabtree, tattooed onto each of your bum-cheeks!!So is it worth getting a password ! should I apply for one ! How do you prove you are a sparky !CJS
just answer the next 5 questions and you gain acess :^O :^O :^OSo is it worth getting a password ! should I apply for one ! How do you prove you are a sparky !CJS
do I get a prize????just answer the next 5 questions and you gain acess :^O :^O :^O whats the colour of the live wire?
red yellow blue black or brown black grey and blue, although the term live is no longer recognised, perhaps you meant LINE.?
what the max zs in 16th edition for a 6 amp mcb type 1
incomplete question, no BS reference provided to ensure an accurate answer
what leakage should a rcd have on outdoor circuit equipment
it shouldnt have any leakage, its there to prevent leakage to earth
where in a property should a bond to the water be installed or the gas (how far from main point of entry)
an E7 done in polypipe doesnt require either
what is the date when rubber was first made?
rubber isnt made, it comes from a tree, so thats really a botany question
answer 5 out 5 correctly and well see admin about a password :^O :^O:^O:^O:^O
yes steps there were a couple of trick questions in theredo I get a prize????Guiness DrinkGuiness DrinkGuiness Drink]![]()
How do you judge what the main point of entry is, sometimes i use the backdoor but usually the front,where in a property should a bond to the water be installed or the gas (how far from main point of entry)
:^O :^O:^O:^O:^O
If you'd been born by cesarean section you'd use the window?How do you judge what the main point of entry is, sometimes i use the backdoor but usually the front,
If windows wern't bonded then wouldn't they fall out in the wind...................I thought bonding windows went out after the 15th edition.
