I had exactly the same problem about a year ago (with a 110v Makita) and ended up just buying a cheap 230v one from B&Q... It does the job and I no longer have to lug a transformer about!!Replacement blades are available!![]()
all the metal frame of the saw is bent. mostly because it gets thrown in a box in the van....before every use, you need to straighten it!Replacement blades are available!![]()
You nicked my saw you ba*****!!!!! X(all the metal frame of the saw is bent. mostly because it gets thrown in a box in the van....before every use, you need to straighten it!
you can have it back! its almost useless!You nicked my saw you ba*****!!!!! X(:O:O:|
you can make your own blades out of an old jetcut saw, i did and works just as good maybe better in some instances .... really good tool for fiddly cuts .Or as Patch says - there is a cheaper version, made by Bosche.Buy the cheaper one first - to get used to it... (Fein Blades are expensive)... And then look at buying the Fein - if needed.![]()
Slight overkill but effectivecould always use a chainsaw.... just make sure you know whats under before you start!
Or dynamite!could always use a chainsaw.... just make sure you know whats under before you start!
even better. get it set up right and itll have the house chased for you in less than a second aswell!Or dynamite!; \
If u used dynamite i think youll be chasing the house down the road :^O are we allowed to use animals as tools??? a beaver is an idea , could chew through the boards and make an access hole u needeven better. get it set up right and itll have the house chased for you in less than a second aswell!
i think a beaver would be a useful tool in those new straw houses!If u used dynamite i think youll be chasing the house down the road :^O are we allowed to use animals as tools??? a beaver is an idea , could chew through the boards and make an access hole u need
and a woodpecker to make holes instead of a drill ... tidysmarti think a beaver would be a useful tool in those new straw houses!
