Sharpend
"It Just Is"
Will we be allowed to use plastic as I'm not sure the metal ones would be suitable for the environment?
As Essex said though, if the cables were properly supported then the problem would be more or less sorted, but how many times to you see tails clipped back to the board... Guess my tails will not be pulling out!!View attachment 2581
Hi Tony, i am not disagreeing!! fact of the matter is that austenitic stainless IS ferromagnetic, but only very slightly, so slight that in my application it is safe to state that it is a non ferromagnetic material.
But, if it was an application more like you are used to, thousands of amps, then yes, there might be a problem, however for my application i think it is safe to say that it "complies" as it were!!
john..
Don't they separate non ferrous metals (like copper and aluminium) from rubbish using induced magnetic fields????
Austenitic stainless, so no, i do not have to have all the cables going through the same hole!! [An austenitic material not being ferromagnetic]
[well spotted though!!]
john..
