Manator, I don't claim to know it all, I don't and far from. I am learning all the time also, that said I'm no slouch either.See, now I have a problem with those who think they know more than others, if you are going to talk about a poly phase system for instance it is proven that there are a multitude of problems with this type of supply. The idea behind a poly phase is for motors, and the main problem we encounter are larger voltage drops on the neutral which knocks the phases out of true 90 degrees.I have been in the business for more years than I care to remember, and yet each day I can and do learn something new.
Having a go at a moderator, and posting in the like of, just shows a lack of respect. I am willing to pass on any information that I can so that people can benefit from all the experience I have gained, and equally I learn from the very good debates given on this forum.
I do know for a fact that if you had posted so on another forum you would have been given a red card, that is the difference with this forum, we are willing to put up with some level of abuse, and moderators are not above any member and use the powers they do have very carefully.
Mr Smith is not an electrician, but a very good judge of character and does not like any childish behaviour, his posts are stylist that's how he has always been, Doc Hudson is from an electrical background and from memory has a long list of qualifications, some of which even I have not achieved. We all can from time to time be mistaken, we can from time to time take things the wrong way, but I like to think we have a very good forum here where we can all learn something without being one up on everybody else.
As for poly phase circuits, a three phase circuit is also a poly phase circuit. And yes the two phase ac phases at 90 degrees ment more current in the neutral as compared to a 120 degree shift.
A forum is only as good as it's members.
---------- Post Auto-Merged at 22:35 ---------- Previous post was made at 22:29 ----------
Sidewinder
I do not doubt for one minute your intellect, I wasn't pointing a finger at you. Im sure your points are perfectly valid, I felt Nick was confused and a simplistic approach was required. After all the adiabatic is an approximation and errs on the side of caution.
---------- Post Auto-Merged at 22:42 ---------- Previous post was made at 22:35 ----------
Where do you want to start?Sooooooooooo when do we get back to the learning bit?
