thebowseat
I live on the ground floor of a Victorian terrace that has been divided into two flats. In the shared entrance hallway is a cupboard containing the two electrical meters, and also the power block (I wasn't at home, my wife thinks this is what he called it?). We had an appointment with an engineer from our electric supplier to come and install a new smart meter for our flat. He said that when the house was split into the two flats, although two meters had been installed, there was only a single power block, meaning the electric supply to one flat can't be cut without also cutting off the other.
The upstairs neighbour, who is difficult at the best of times, refused to allow her electric supply to be switched off for 30 minutes for the job to be done. This led to the engineer leaving, job not done.
I have a few questions,
1. Is this usual, that a split property will only have one power block? This seems to pose issues not only in this instance, but if for example one property didn't pay bills and was to be cut off?
2. If this is unusual, is it mandatory to have two power blocks, i.e. one per flat? If so, who would enforce and install this?
3. Is there any recourse I can turn to to have my neighbour stop blocking the work being done? Asking nicely won't work, she's not that way inclined sadly.
Thanks in advance,
Thanks in advance,
