Tysoft Easycert - How do I change the colour?
gselectrical
Oct 13, 2009
627
Evening all
When I first installed Tysoft Easycert a while back it gave me the option of what type of cert i wanted. Bog standard, NIC over print, Red NIC cert etc.
At the time I chose the standard blue cert. Does anybody know how I can change this to a Red NIC cert without having to re install the software?
Cheers.
GS
When you open a new certificate, it gives you an option then to select the certificate type. Hope that helps.
If the option is "greted out"; it means that particular cert. cannot be issed in that particular colour (commercial / industrial certs can`t be printed on a purple form!) ; though domestic can be any colour, and a few can only be red.
KME
