- Nov 28, 2009
- 14,681
- 832
Then a double + 1.
Or patch a new bit of plasterboard in.
+1. I wont buy any other, especially the crap ones with the stupid blue lug that doesnt stay in placebut you won't go far wrong with Appleby ones.
Nah! Some low expansion gun foam and a sharp knife would sort that!you might get away with using some 15mm metal angle or L-section for top and bottom of the row of sockets, and possibly the sides too.
Looks to me as there will be no gap between the faceplates, and no danger of the decorator filling the boxes with falling filler.
Like this
The foam might crush when the faceplates are screwed on, and when someone plugs something in. Also there might be problems with ignitibilty in the enclosure.Nah! Some low expansion gun foam and a sharp knife would sort that!
It is just two (possibly 4) bits of metal (aluminium?) screwed through the plasterboard with self-tapping screws. Hardly fabrication ; -)i wouldnt be making a frame from steel because the plaster is too lazy to do his job properly
Why should cables not be hanging out of boxes?You leave cables hanging out of boxes? Not surprised the plasterer has it in for you.
I can coil cables in a box and leave enough slack for slight alterations. If you are having to do major alterations after the plasterer has been in on a regular basis I would review the reasons why. I see no reason to make other trades lives difficult, it works both ways, I gain respect from other trades by being courteous.Why should cables not be hanging out of boxes?
If i have left my cables at whatever length it is for a reason, there is no need for any plasterer to cut any cables. It is nothing to do with them. I do not like to squash mine in the box, and i often leave a little extra in case something has to be altered.
Erm........had hoped the tongue in cheek meant I wasn't being serious! :lol:The foam might crush when the faceplates are screwed on, and when someone plugs something in. Also there might be problems with ignitibilty in the enclosure.
Just trying to think of a way to make everyone on the site, including the client, a bit happier.
Should we not do our jobs properly, just because someone earlier in the chain didn't do theirs?
Would be an extra of course.
There's a bloke I used to sub to that would have a 10mm² earth bolted to that as well.you might get away with using some 15mm metal angle or L-section for top and bottom of the row of sockets, and possibly the sides too.
Remember that mutual respect thing? Yeah, that's why plasterers don't fill my boxes, rather they usually clean the boxes out for me if they have inadvertantly got a bit of plaster in there.putting cables in the boxes for plasterers, encourages those idiots to float there trowel straight over the top of the box and fill it with plaster.
