Hi all
Can someone please explain this for me ?
If you have a ring on 32a mcb etc and you install a new socket and wire it directly into the db on same 32a mcb as ring its a minor works as not a new circuit but i thought it needed an E.I.C. as its a one socket radial and a ring in same protective device as you can remove the ring and the socket will still work as a radial.
Regards
Kung.
Regards
Kung.
