Hi folks another little issue has cropped up to do with electrics and would like a bit of advice from you good folk here please.
I live in a first floor purpose built maisonette if you count the ground floor as just that. There are four maisonettes in the block, two on the first floor and two on the ground. They were built in the late 50's, you could easily mistake the block for a couple of semi detached houses other than the street doors are on the sides of the building. One near the front of the block and the other about half way along. The same on the other side of the building. Being a maisonette there are no communal areas. My door is the one near the front of the building. There is a cupboard under my stairs at the side of the building between my door and the downstairs maisonettes front door. It was formerly a space to keep the bins pre wheelie bin days. The old bins are gone so it's now used as a shared storage space.
The leaseholder downstairs had a major refurb done last year including a full rewire. A group of east europeans do the job led by the electrician who is also from that neck of the woods. Before the refurb took place I spoke to my new neighbour who was a first time buyer and stressed that he would need to comply with part P of the building regulations and informed him he would need to have a gas safe registered engineer for any gas work.
Right that's enough of the back ground to the story. Here's the meat. Shortly after the refurb I discovered there are a number of cables protruding through the storage cupboard wall near to a shelf were I keep some garden equipment. Sheers small hand spades etc. My lawnmower is in there on the floor an its covered with bits of brick and brick dust. Behind the wall is the area where his meter and consumer unit reside. He has seen this but he's not in the least bothered, did not even bother to offer to clean up the mess. When I asked him if he had a part P electrician do the job he said he'd had an electrical inspector out who passed the work. When I asked him what competent persons scheme the inspector was qualified under he went all vague and said "oh I don't remember, something with a lot of letters"
Can someone advise me whether the cables should have been left like this and what is the best course of action?
Thank you
Thank you
