Doc Hudson
- Oct 21, 2008
- 5,618
- 230
I think you will find the MK instructions are with the MCB or RCD or RCBO or Main switch. Some wording like, "For use in a Sentry Consumer unit". Which implys it is not for use in other manufactures units.I've just spent a dull 20 minutes reading the MK technical brochure with installation instructions. At no point do the instructions say to only fit MK breakers in an MK board. The characteristics are given for the breakers, but at no point does it specify only to fit in an MK boardhttp://www.free-instruction-manuals.com/pdf/p3265650.pdf
Now I understand it would contravene the regulations if it did, but you find it written down in black and white for me!
The implication is the MCB would function as described in any environment, not just an MK enclosure
