Doc Hudson
Moderator
- Oct 21, 2008
- 5,620
- 230
I posted the instruction page from a Wylex C/U recently on a similar thread. It states certain BS numbered breakers only that must be used, not manufacturers. It also did not state a torque setting but did say use Phillips No2 driver.
I read it that Slipshod is confirming in his link, what you are suggesting Prodave and what he also suggested in an earlier post.Am I missing something, but I can't see the bit where it says you must only use Wylex MCB's.As far as I can see it just gives the BS No's of what you can use?
It happens to mention in passing the temperature ratings of their own MCB's, but at no point does it say they are the only ones you can use.
So this thread is all a red herring, at least as far as Wylex boards are concerned then.
