I think that, in that instance, the bigger worry is them having increased your disconnection times to 5 seconds for you!I dont mix and match never liked the idea and hate it when PV installers do it to my boards.
The issue here is that due to some changes in the law manufactures have changed their directives given with some new products..So you get to a job with a board 25+ years go to the van and take out the mcb you stripped out of a job last year. Now your putting an already used component into this existing board. I'm sure theres a get out clause there for the manufactures. Can't really win.
The spare way I leave for them would be on the supply side of the protective device inline with the diagram in 7671. So even they cant get it wrong!I think that, in that instance, the bigger worry is them having increased your disconnection times to 5 seconds for you!
The danger being discussed, is if you feed into an MCB that's fed from an RCD, then in the event of an earth fault, the RCD will trip, but all the circuits will still be energised from the PV generator, that will continue to push out power for 5 seconds before it realises it's lost it's grid lock and shuts down.Wozz,I don't have my book here, but, if you are feeding "into" a CU via an outgoing way then I don't see how it can be on the supply side, however, I don't have the diagram you refer to here, my memory is rubbish, and, I don't know your installs!
You could have ironed it before you scanned it...Couldn't find the link so here is the same scan of the current Wylex instructions![]()
And it looks like i was lying about the torque settings, Its Logic & Hager that does not give any .
I phoned the kids the other day to ask if they knew where the thing that irons the clothes was, they replied 'she left you last week'You could have ironed it before you scanned it...those creases give me a headache!!
]ROTFWL
Good point, i never thought about that as its very rare i fit a C in a C/U (and only ever fitted a few D's in commercial)So no C or D types in that CU then?
Am I missing something, but I can't see the bit where it says you must only use Wylex MCB's.Couldn't find the link so here is the same scan of the current Wylex instructions![]()
