Wago Dinrail Mounted Connectors & Compact Rcbo Job
M107
Billy-the-Kid
Feb 18, 2008
5,561
28
Berkshire
For the first time I have used the Wago Box din rail mountable connectors, the push fit ones are so much faster to install and use than the older screw terminals.
I would recommend them to anybody who has the need to extend multiple conductors, they make a far neater job than other methods.
Anyway here are my pictures of todays job where I used the Wago connectors & enclosure: move a cu from it's external loctation to inside the property & relocate further away from it's external location.
The old cu.
http://i83.photobucket.com/albums/j293/gazjothomas/20130808_090633_zpscb711f9f.jpg
New tails in. Diamond tipped cutter through the baked brick (as hard as a modern engineer block).
http://i83.photobucket.com/albums/j293/gazjothomas/20130808_111436_zps8a5e2fd9.jpg
Wago Box enclosure & connectors in.
http://i83.photobucket.com/albums/j293/gazjothomas/20130808_122618_zpse04335bc.jpg
Old meets new.
http://i83.photobucket.com/albums/j293/gazjothomas/20130808_130628_zps233e73b6.jpg
New MK enclosure & compacts from SBS
http://i83.photobucket.com/albums/j293/gazjothomas/20130808_111359_zps761d4456.jpg
http://i83.photobucket.com/albums/j293/gazjothomas/20130808_111414_zps75102a4d.jpg
Conduit drop with 16mm to new rod & 10mm to MEB's
http://i83.photobucket.com/albums/j293/gazjothomas/20130808_151708_zpsce66b818.jpg
Completed job.
http://i83.photobucket.com/albums/j293/gazjothomas/20130808_171534_zps36458403.jpg
http://i83.photobucket.com/albums/j293/gazjothomas/20130808_171846_zps19853b03.jpg
http://i83.photobucket.com/albums/j293/gazjothomas/20130808_171854_zpsf6dc51f7.jpg
Looks a really neat solution to a common problem.
Don't suppose you have a bigger version of the view inside the Wago enclosure. Really tiny for a good look.
^^^Just incase there isn't one I found this...
Top Job M107 :)
Should have mentioned that the image is from an American automation company, although the power supply to the intelligent connectors on the left is 230v and the writing is in German  :innocent
Biggest image I could find so you can get in close :yawn
Very neat installation, nice work.
I had some reservations about the form factor of the DP isolator, it doesn't seem to align very well with the busbar but you can't always tell from a photo.
Hi Marvo,
I assume you are talking about the DP switch in my Compact Board.
The body length of the switch is about 3mm shorter than the RCBO, so your observation is correct.
However, the pin going into the switch is 8mm wide and 15mm long, so electrical continuity is better than the 5mm wide pin used on most other manufacturer's bus bars.
It is interesting to note that some MCBs and Main Switches from Electrium are so mis-matched, that they have to put an offset in the Main switch busbar pin, in order to achieve proper busbar alignment. This in turn leads to a shorter insertion length of the Main Switch pin, which I believe may be your objection to my set-up.
You will be re-assured to know that future Main Switches supplied by me, will have a body length the same as the RCBO. It is a heavier duty unit and will sell @ £6.00 instead of £5.00.
SBS Dave
Nice neat job mate
if I was the customer I would be chuffed to bits with that,,,,,even more so once I had taken the yellow warning sticker of the cu ;)
