For the first time I have used the Wago Box din rail mountable connectors, the push fit ones are so much faster to install and use than the older screw terminals.
I would recommend them to anybody who has the need to extend multiple conductors, they make a far neater job than other methods.
Anyway here are my pictures of todays job where I used the Wago connectors & enclosure: move a cu from it's external loctation to inside the property & relocate further away from it's external location.
The old cu.
http://i83.photobucket.com/albums/j293/gazjothomas/20130808_090633_zpscb711f9f.jpg
New tails in. Diamond tipped cutter through the baked brick (as hard as a modern engineer block).
http://i83.photobucket.com/albums/j293/gazjothomas/20130808_111436_zps8a5e2fd9.jpg
Wago Box enclosure & connectors in.
http://i83.photobucket.com/albums/j293/gazjothomas/20130808_122618_zpse04335bc.jpg
Old meets new.
http://i83.photobucket.com/albums/j293/gazjothomas/20130808_130628_zps233e73b6.jpg
New MK enclosure & compacts from SBS
http://i83.photobucket.com/albums/j293/gazjothomas/20130808_111359_zps761d4456.jpg
http://i83.photobucket.com/albums/j293/gazjothomas/20130808_111414_zps75102a4d.jpg
Conduit drop with 16mm to new rod & 10mm to MEB's
http://i83.photobucket.com/albums/j293/gazjothomas/20130808_151708_zpsce66b818.jpg
Completed job.
http://i83.photobucket.com/albums/j293/gazjothomas/20130808_171534_zps36458403.jpg
http://i83.photobucket.com/albums/j293/gazjothomas/20130808_171846_zps19853b03.jpg
http://i83.photobucket.com/albums/j293/gazjothomas/20130808_171854_zpsf6dc51f7.jpg
The old cu.
Old meets new.
Completed job.
