avinalarf
- Joined
- Jun 2, 2008
- Messages
- 415
- Reaction score
- 0
Hi all
Just went to look at a job which turned out to be a lot larger than telephone call let on!
Anyway my queries are:
1 - does anyone know of small light fittings which can be placed in a wall which are battery operated or are of the PIR type?
2 - couple have put their w/m in the downstairs loo; they want a SO for it. Had a look in the BRB, but can only find info for showers and baths. Would I be able to put a switched FCU in there? The distance from the sink to the wall is only 0.9m.
3 - can any light switches with big rockers and an indicator to tell you that the light is on be found? (before anyone says "just look at the light"!, it's for a switch which operates the loft light).
Thank you all
Thank you all
