... to add a socket in my daughters bedroom.
Well, more like 3 hours to do it, but 3 years to get around to doing it
Should have done that bit first, and stuck a bit of tape around the other end. Sorted.you lot are slow...
says the one who put in a cable for a wall light about 4 years ago and its still sticking out of the wall... one day i will get a light... and then another day i may connect the other end to the supply
Plug n play lighting?Should have done that bit first, and stuck a bit of tape around the other end. Sorted.
i probably should have, since the loft has now been partially boarded, so its probably going to have to be extended to reach a light in a different room that is accessible...Should have done that bit first, and stuck a bit of tape around the other end. Sorted.
5 years to do a job? what did they want? and entire house re-wired?!5 years ago I had a few days with no work on the books so decided to install an alarm . Panel on the wall with the front off , wiring in, the phone went with a job and thats as far as it went .
I may well need a new spade before she needs a new kitchen,If she carries on with such slander I can see you needing a new bigger patio!!
