springcrocus
- Jul 3, 2008
- 588
- 0
My cat just digs a hole and pees in it . Would that get your Ra even lower?
Tell us summat we didn`t knowSteps, get us another can of lager when you go out to the fridge will you please, my glass is empty.
LMFAO - you`d have had a problem SAYING "bread" ; let alone spotting it - it travelled quite fast, as I recall....................And some bread well buttered please :slap
No, course he doesn`t mate - that would necessitate there being a definite demarcation between alert and Zzzzzzzzzzzzz - and, afaicr, there wasn`t one.do you want a sleeping bag with your vino?????????
Ok I'll have a bash...TT to TNCS needs connection between cpc and N.
As RCD is balanced ,then a cross wire to keep both conductors balanced would disable it....my answer either short or crossed wiring on RCD circuit ?[/quote
No "crossed" wiring.
A short between L-N would have tripped the MCB.
Would not a short from N-CPC have tripped the RCD?
Only one faultI will have a go could it be possible that you have a L-E and N-E fault and they are balancing out the RCD Thus causing it not to trip? ray
will you folks never get your priorities right?Ok is there a fault at the star transformer or was the system previously a TNCS converted to a TT and someone forgot to remove the link to the neutral? Failing that I don't no, and it's time for football bike racing and alcoholGuinness
