Tell me when you`re going m8.
I`ll be there. (Haven`t been up `ome in a while, now)
:z :z:z:xPrayI've just noticed the time. I must go sleep too. Will read the rants in the morningNight all
eh?Well, he needs to ingest & (at least partially) understand the theory behind that thread, before we try to go on...........................p.s. 200 lines, and a sound spanking with a wet lettuce leaf!
indeed so....... I personally put all outside equipment fed from a house on its own trip...........Out of RCD unit in house via armoured cable if possible (better to run back to cu and terminate thereearth armouring dont forget....
MMM. I can think of a huge number of account of T&E been ouside unprotected. Are you saying it's against regs or just not good practice.firstly TWIN AND EARTH should NEVER BE USED OUTSIDE ESPECIALLY ACROSS A SUPPORT WIRE OF ANY KIND![]()
It's got it's own way in CU so on it's own MCB on the RCD side of the boardindeed so.I also try and stick external supplies on their own MCB as well..
i would class it bad practice and i think it may contravene to mechanical protection of the regs, will look in the red book after workMMM. I can think of a huge number of account of T&E been ouside unprotected. Are you saying it's against regs or just not good practice.In my defence a proper spark designed the set up. NAPIT and everything. I've got a certificate occifer. :S:^O
