they do mate, thats why its a major problem, fault comes back in through your rod,Yes there's an RCD.I can't see why each house can't just have it's own rod. It would surly be simpler...........
Steps, anyone that anal about their hi-fi systems deserves what thet get.Some of them seem to believe that buying a
So if you separate the garage from the house to avoid exported earth, and use an earth rod, then there's no advantage, cos the fault comes back up the rod ?:| ? :| ?:|they do mate, thats why its a major problem, fault comes back in through your rod, protective multiple earth, spiked at multiple points along its length, obviously if you neighbour is on the same T as you then you share everything, phase, neutral, earth and FAULTS.
the problem with PME is that its so simple its DANGEROUS,!
NO, cos if you have done it properly then the fault cannot come up the rod cos it has no where to flow to, you have disconnected the return to earth via the house PME.So if you separate the garage from the house to avoid exported earth, and use an earth rod, then there's no advantage, cos the fault comes back up the rod ?:| ? :| ?:| Or have I misunderstood something.
Also begs the question about bonding in premises split into flats where each flat is fed via switch-fuse and from there in 16mm FTE - do you bond in flat to CU or return all bonds to MET adjacent consumer head?
Having asked the question I'm off to read books :z :z, cos I now doubt what I thought I knew about this scenario.
I see where you are coming from,would he not be exporting TNS it is tncs where it comes into the property then it is seperated , so in fact he will be exporting tns
do you reckon the IEE will cover your ass for you in court?try this link apache they dont say that exported pme is wrong to a shed http://www2.theiet.org/publish/wireregs/wiringmatters/documents/Issue16/2005_16_autumn_wiring_matters_electrical_installations_outdoors.pdf
also I would not disconnect the earth wire from your support wire
qfa qfa qfaThe only problem with pme is if you loose the neutral but if the shed has a rcd fitted it would detect the imbalance in the live and neutral so would disconnect.I do understand what you are saying step but in my 20 years experience I have never came across a lost neutral on the supply but i have come across loads of high reading (ra) rods and malfunctioning rcds.also if you did loose the neutral on the supply it is staked down to earth in multiple places along its length the only problem would be if you lost it from your installation to the joint in the road or over head.what are the chances of that (slim).as for Code1 I think your are being a bit over the top
I think thats a BIGGIE, not really like dropping a switch wire from your 2way lights is it?The only problem with pme is if you loose the neutral but if the shed has a rcd fitted it would detect the imbalance in the live and neutral so would disconnect.I do understand what you are saying step but in my 20 years experience I have never came across a lost neutral on the supply but i have come across loads of high reading (ra) rods and malfunctioning rcds.also if you did loose the neutral on the supply it is staked down to earth in multiple places along its length the only problem would be if you lost it from your installation to the joint in the road or over head.what are the chances of that (slim).as for Code1 I think your are being a bit over the top
in the words of a better man than me.Guys, sometimes funerals don't exist, until an accident occurs.Don & His Boys.
