- Mar 28, 2008
- 14,354
- 1,007
Agree with bad practice there Badger... but I think again this is one of those areas where the regs don't specifically say you cant...i would class it bad practice and i think it may contravene to mechanical protection of the regs, will look in the red book after work
electricians guide to building regs...
IMO...pg 685.7 garden light power shed & garages..
5.7.2 PVC cables should be protected from direct sunlight exposure.
permanently fixed in a protected location. (e.g. IMHO a shaded wall..)
Or mechanically protected
Or buried.
later its says UV will deteriorate PVC and should be replaced after 15 yrs..
common sense says a short run to a light fitting can look really ugly with SWA or conduit over it, so PVC can be more aesthetically pleasing.
wheres as a long run to an outbuilding...
best put in SWA or PVC in conduit!
Also re the PVC T&E on an overhead... have seen this numerous times myself... but I wouldn't install that way...
normal T&E is NOT a flexible cable.. and not best suited to blowing around with movement in the wind! or animals climbing over it! :|
whereas SWA is not a solid core cable!
