Ist post! Resurrecting an old thread as it had the same title I would write!
Hob 10.8Kw
Ovens 2x 3.4Kw (spec says 16A hard wire)
Steamer and Microwave (built in)
10m run on average from CU all clipped to solid all RCBOs
Head spinning with the options.
Thinking of 40A/45A 6mm to the Hob, could use 10mm but it will make life difficult
Cannot see any other way to do ovens than 2 separate 16A runs in 2.5
Built in Microwave and steamer off the ring
Other thing is this will need 4 DP isolators if I go that way and space is at a premium above counter. Don't really like the idea of attaching 6 or 10mm to boxes the inside of a cabinet and no real space for a grid within 2m. CU not much further than 2m. Add the isolators for the washer and dishwasher and it starts to look a little busy to say the least.
trying to get a good plan that doesnt look like a DP-switch scattergun
