Wiring Control Panel Without Bell Box.
Dnandhara
Apr 18, 2015
Leeds
Hi,
New to the forum. I will be moving house soon and my wife wants to take the current bell box with us. ( stainless steel rapier bell box)
I have dummy bell box which I could replace it with. But how do I tell the control panel that there is no bell box connected.
Current wiring of bell box:
Control panel.
Str - Green
T- White
A. Black
D. Red
B. Blue
Bell box.
Str. Green
Tamp return. White
Hold- Black
Hold+. Red
Trg. Blue
If I remove the bell box the alarm will produce a fault with bell box. So do I need to short the tamp return in the control panel? Do I short to A or D?
Thanks for the reply.
On the fixtures and fittings form, I've indicated house has a fitted alarm but bell box not working.
I was going to follow the following procedure:
1 turn off power to control panel
2 remove cover off the control panel.
3 the alarm will go off. Disarm by entering code.
4 remove wiring for bell box. I think at this point the bell box should go off for 20 mins.
5 short T to A on control panel.
6 put cover back on control panel.
7 turn power back on to control panel.
8 remove bell box , but when I take of the cover off the bell box will it go off? Or should the internal battery be flat?
9 replace link inside bell box. I remember having to cut a link wire inside bell box when it was fitted.
10 fit dummy bell box.
Does this procedure sound right.
Thanks.....
I would leave the bell box, sounds a bit mean to me taking it when your are probably dealing with thousands and thousands of pounds for a house sale, but I don't know your circumstances of course.
Just tell your wife you have enough things to do sorting out with the move and don't be so tight :)
Good luck with and please post pics of your black eye :)
Rapier bell boxes (There are electronic sirens really) start at £100 and do look "posh" which is probably why the O.P's O.H wants to take it. Personally I would not bother.
_________________________________________________
Dnandhara
Don't bother turning the mains off before you open the panel, you may find out the hard way you have a low / flat standby battery..
From your list:
5: install a permanent link
8: It should, but depends on battery condition.
Don't worry about the link, just disconnect the battery (or wait 20 minutes to be sure)
